Chainsaw help and info.
My parents neighbor had me take this out of his shed, it was there when he bought the house over 30yrs ago and he's never even tried to start it. It's a Clinton model D50, from the little bit of research I've done it was made in 59. It appears to be complete minus an air cleaner, I gave it a good soak with degreaser to clean it up. If I can get it to run what kind of value does it have? I assume the carb will need rebuilt, where's the best place to find parts?
I think mjsoldcub is they guy tou want to talk to. I think John Hall also plays with old saws.
Curiosity got the better of me so I gave the carb a small shot of brake cleaner and pulled the cord twice and it fired right up and ran for 4 or 5 seconds, I don't have any two stroke gas at the shop so I will take it home tonight to see if it will run on gas.
I've only got One Clinton, a little different from yours.
First a few old chainsaw basics--Most of the OLD saws are loud--really loud. A lot, including my Clinton only have an exhaust trumpet--no muffler. Do yourself a favor and don't try to crank it indoors--ask me how I know. Most older saws ran a 1/2 pt of 30w oil to the gallon of gas. I'm not going to debate modern oils, do as you wish for oil/gas ratio----most old saws had a decal on the tank or cast the ratio in the cap. If I had to guess you have round pancake looking tillotson carb. Parts may be available. Sometimes diaphragms get to the point they can't flex well enough to pump. I have heard of briefly soaking in brake fluid, but it may attack the material--proceed with caution. Interesting info here. http://www.acresinternet.com/cscc.nsf possible supplier for carb parts--call them http://www.vepetersen.com/ If you get really interested in old saws, look up a Strunk--made in Coatesville, PA I think. I have 2--one blends its own oil/gas
Tim,
I have 3 Clinton parts manuals and the closest I can find is a D35. Let me know if you need a copy of it.
What do you get the guy who has everything, for Christmas? No......really......he has everything
I do have some engine to carb gaskets for Tim.
probably easier to ask what Lew doesnt have!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
Thanks for the info. I did put gas in the tank but can't get it to run so I guess the carb needs to come apart, haven't had time to mess with it beyond that.
The diaphragm may get flexible after it soaks in gas for a few days. Some of those old saws use a metal fuel filter, kind of a laminate or perforated bronze looking setup.
