I have one I need to take apart and I know I will not be following this guys video.When two minutes in he called it a squash plate I knew something was very wrong.I guess it's kinda like a train wreck,not something you want to see but tough to turn away .I watched another part or two and he did get it to work that, I think says more about how well these things are made .Even after what he did to it it still worked.I may have a chance after all.
Bob |
my wood splitter has a k341 on it the guy that gave it to me had the motor all wrapped up nicely. after ten years out behind his garage the tarps pretty much rotted off of it. the mice had moved into the fan shroud and the lower half of the ring gear was gone along with the bottom of the fan shroud. the aluminum bearing plate was also rotted thru i think when the oil came out the mice left. replaced the rotted parts and its since then split alot of wood. so i would say mouse piss is pretty corrosive. the bearing plate looked alot like the rear of his hydro pump
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I just watched a guy beat a kohler block to hell in pieces , I can't watch this video. Here Jon have some bourbon! Lol don't have any scotch!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Thread Tools | |
Display Modes | |
