I can't wait to see the future Cub parts you make.
You must have been a good boy this year, no doubt about it.
Are you going to restore/rebuild it, or is it ready to run as is? I wish I had the skill to run something like that. They're out there and available as folks update to Haas, and other CNC mills. Now to make some parts! John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
John, my plan is to clean it thoroughly, sand the rough spots a little and then give it a coat of machinery gray using a small foam roller meant for cabinets. They really do a nice job and no brush marks. Of course I'll have to use a brush in the tight spots, but I have found using a 1/2" wide artist's brush works very well. The artist brush bristles are so fine you can smooth the paint out nice. The previous owner went totally through the entire mill two years ago, doing upgrades and replacing worn parts so it's ready to use. Since it's overhaul, it's probably only been used maybe 20 hours.
I'm not a skilled machinist by any means. I have run a mill a little bit. I thought about taking a couple courses at the local vocational school. The have some night classes geared to old fogeys like me.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Nice Christmas present! Now I'll drop off a couple K blocks for your weekend project to bore oversized when I go the the Nascrap at the Glen next year!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Great purchase Stand! Don't spend money on a Rotary phase converter or a static phase converter, you just need a variable frequency drive, I use a Teco FM50 2hp VFD to power my Millrite milling and my Logan Lathe ($167)
http://www.factorymation.com/ac_drives_qs/FM50_Series
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
That is sweet Doc! I want one too.
+1 on what Gilles said. If you are using a 3 phase only VFD and applying single phase to it you need to derate the VFD. The easiest way to do that is multiply your motor FLA by 1.73 and make sure your VFD can output the calculated amps.
Started down the clean and paint road. I'm doing one section at a time, cleaning thoroughly with lacquer thinner then some light sanding to blend the chipped paint. The Rustoleum Smoke Gray Gloss is going on well and since I'm using a very fine artist's brush, there are very few brush marks. The red is also Rustoleum - Safety Red.
Now you need a DRO
That's part of the long term plan along with power feed for the X and Y axis.
Thread Tools | |
Display Modes | |
