Deck compatibility question
Will this deck for a 127?
35819x 44c 0320023u |
Will it what??????????
Maybe color means alot?
No
44C is for an 82 series. |
'82 Series was St. Louis vs Milwaukee.
Seriously, you can look it up! |
The 44c uses a 5/8 inch belt, your tractor PTO wants a 3/8 inch belt. Also, the mule drive (that mounts to the front of the tractor with idler pulleys) for the 44c (and 44a, 50a, 50c) decks have canted idler pulleys to accommodate the offset center drive pulley on the deck.
The 44a (and 50a) are similar decks with the narrower pulleys. You can use the 44c if you replace the center pulley on the deck with a 44a pulley (for the narrower belt) and put a different mule drive on the tractor. I'm pretty sure a mule drive from a QL (e.g., 1000, 1250, 1450, 1650) will fit and should have the canted idler pulleys. You'll need a different PTO to deck belt. I am in the process of converting a 44c to a 44a, for use on my 108. So it can be done. All the parts are available--pulley and belt at various CC suppliers (I use ccspecialties.org) and the mule drive is probably on ebay or you can look at some of the used parts suppliers listed in the resources forum on this site. I'll note that sometimes it's easier to just get a different deck, one designed to work with your tractor. Good luck.
Good description about A deck drive systems and "How to" C deck fitting! Thanks for the sharing Fred
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
You mean Frank, but I agree!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
On a C deck you also have to move the left front hanger to the outer hole to make it a A.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Part of the mower hanger needs to be modified for it to fit on a narrow frame.
http://www.cubcadet.com/equipment/AR...0-A/0074200004 Part #6 needs modifying at saddle bracket.. the part that slides over bar in the tractor frame.
Queen Of The Quietlines! |
