Sorry i meant they are closer to the same size. Center is just slightly bigger.
Centerblade is slightly bigger not much in regards to the gentleman describing the differences of the deck so I do believe it's a 48 inch deck
The absolute easiest way to tell are the spindle covers. If they have one hole, it's a 48" deck. If each cover has 2 holes, it's a 38" or 42". If the spindle is under the outside hole, it's a 42". If it's under the inner hole, it's a 38". Of course this doesn't apply to the first series of decks, the ones with the cast end plates. If it has cast end plates, it's a 38" or 42".
You need part number IH-489397-R3. 3/8" x 75.5". It's number 14 on the diagram below.
http://www.cubcadet.com/equipment/AR...0-A/0075600004 |
U guys are awsome thanks. Ill keep ya updated as i had. More things. To figure out
Pictures of deck 48" pin on and 48" QA.
Mine looks like the one on the bottom when i get off work im going to get pics of everything and post them
