782 quick release
hello all i tryed to use a dirt blade but on the quick release lever the spring came off blade detached any idea where to get spring part # etc. and how it attaches thanks all
The quick attach blades can be ripped off easily even when the spring is on, I made some locks and it solved the issue.
http://www.onlycubcadets.net/forum/s...ight=Plow+lock
sorry i did not give enough info its the mule drive quick release it has no spring need to get one and know how it hooks on thanks
Picture would help. I have no idea what you are talking about. Mainly because I don't have one. I would like to know what the parts are anyway.
it hooks on the rod dead center and up over the frame on inside under grille , some models have a small hole they hook into .
any idea where to get the spring thanks for the info
I assume this is the spring.
yes sir that is it do you know part # or where to get it thank you very much
Your local hardware store must have a selection of extension springs.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
It is still available through Cub Cadet, but I would try the hardware store first. That is a little pricey.
http://www.cubcadet.com/equipment/cu...2&pageNumber=1
