I'm wondering if anyone uses electrolytic cleaning on the flywheel? Curious as to whether there would be any issues putting the magnets in there.
I don't think I would chance that if I were you. If it doesn't destroy the magnets, it would likely loosen the adhesive that holds them on the flywheel.
I didn't put it in the citric acid-based cleaner I've been using because I was concerned about the magnets. I guess it doesn't really need to be de-rusted, being under the blower cover and all. But it sure is ugly.
Revese electrolysis for gas tank?
I am considering trying a "reverse" electrolysis on a 124 gas tank. Instead of dipping the entire tank I thought that if I could get the pos electrodes to hang inside, from the cap opening, and hook the negative to the tank itself I could push off repainting till spring and get the tank insides rust free.
Is this a mistake someone has already made? Any suggestions are welcome and appreciated. |
Is the drain cleaner/lye used with a battery charger - or just as a caustic broth?
Thanks, Calvin |
12amp. Car battery charger. Nik, |
Guy's
I can get a free stainless steel milk tank and I was wondering if that could be used for this process or do I need a plastic tank? Thanks for your input in advance. Sam |
BUT, I would still suspend insulated conductor plates so the tank is less involved in the process. |
OK if I understand this, I want to keep what I'm cleaning and the plate that the crud is attracted to insulated from the tank? Don't see that as a problem. Nice thing about this tank is it looks like it's big enough that I can put a complete frame in all at once.
Just noticed that Matt G said "Do not use a metal tank" so if not why not? I'm new to this idea and have no great desire to blow myself up
