Steering Wheel Removal
Hi guys, I have been trying to get the steering wheel off my 128 with no luck. I removed the nut and soaked with PB blaster for a few days. Put nut back on leaving about 3 threads left. Did the knees under the steering wheel thing and using my air hammer. Also tried hitting the nut with a hammer squarely only to ruin some of the threads on the steering shaft. Lastly I tried using my puller. All these with no success. Any other ideas of things I could try? Any help is appreciated.
I had the same problem on my 169, I tried everything. The thing that finally worked was to put the nut back on and tighten it down very tight, breaking the hold between the wheel and shaft. Then it came right off with my puller.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel. |
2 ball joint forks worked awesome with mine in with one and then set the next one on top of the first
1967 cub cadet 125 Cub cadet 102 cub cadet 71 |
looks like it is time for mr. Sawzall
Your right Lew, Mr. Sawzall and the torches. I have never had this much problem with anything on a Cub until this steering wheel. The shaft is ruined. Apparently someone marred up the splines really bad at one time and looks like they hammered on the steering wheel
I may have just the steering gear shaft,I will let you know.
I'm having the same problem with my 147. I finally managed to break the nut completely off using a 'small' amount of impact. Now I need another shaft...when I get this one off.
Post #2 is an interesting approach.
You can try making one of these....
I use a bearing splitter.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
