Sprayer trailer I built from scrap metal
I was trying to decide between building a 3 point mount bracket for my new sprayer or a trailer. The trailer seemed like the best option for many reasons. The trailer was built with scrap metal that I've collected throughout the years. The only things I had to buy was a 5/8" steel rod for the axle and some cheap harbor freight tires for $4.00 each which were actually bought about 3 years ago. At first I was thinking about putting a quick disconnect on the pump so I could use a coiled hose when driving or the longer hose that came with it for when I park and spray. The quick disconnects would allow me to swap hoses out in seconds, but instead I've decided to build a hose reel (from scrap metal) in front of tank and just use the hose that came with the sprayer. Also pictured is a cool trick for drilling the steel rod when you're poor like me and don't have fancy tools. I've also used a heavier version of this clamp and a hole saw to make the fish mouth when welding one tube to another, just remove the pilot bit and clamp the pipe with a board between it and the drill press for the hole saw to go into. .
One lonely old 1541, 3pt, Brinly plow and cultivator. |
Nice work o---o
Agreed! I need to build something like this. I have a tank, just need a pump and something to spray with.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Very nice work.
Looks great!
Thanks everyone for the compliments! I haven't sprayed any chemicals yet, but I've tested it with water and I can tell this will make weed control so much easier this year. I usually spend 40 minutes on the mower and 50 minutes with the Cub Cadet string trimmer. I wish I had this trailer years ago lol. I really wanted to paint the trailer Cub yellow, but I have over a dozen cans of black already so I reluctantly sprayed it with them. At rural king I saw they had a 1 gallon per hour pump for $40 and a decent sprayer wand for $22, or the whole 15 gallon tank on sale for $61 with everything (normal price was $80)
looks good. It is time for sprayers again. sigh...
Very creative on the bar drilling. I use a HF v block for my rod holes. Center drill to start it then change to drill bit. Don't have to mess with clamping. If no center drill then grind a little flat spot for the bit to start on. |
Is this the one you have? http://www.harborfreight.com/self-ce...jig-92046.html
Yep. Makes round things much easier to work. Also helps with clamping round things together. When fabricating set on a pipe gives a flat spot for a clamp to hold it.
Thanks, it does look useful. I'm adding one to list of things to get from there next order I place
