My red-neck blade lift
I wanted a quick, simple, temporary, yet sufficient way to lift my blade.
I took out the grill and made this frame to "pinch" the front end and mount a winch. He's a view under the hood where the frame mounts to the inside of the front end. And a view from the front. I just wrapped a chain around it to attach the winch cable. The winch is a Harbor Freight remote control unit. I disabled the remote function and wired it to a rocker switch with a kill switch. |
Looks like it will work good and probably lift higher than the original lift.
Nice work.
Chip T. Drexel NC |
Works for me, I may do something along the same lines for a rear lift on my 71/121 project
cool, if it works... it works. could use it if you ever get stuck too.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Good job on the blade lift!
I have the same style winch from HF.
How did you go about disableing the remote switch? My FOB no longer works and the winch is no good without it working, and I no not how to bypass the remote switch. |
lonnyb, I "Googled" it and found the same winch I have. A guy explained how to do it on his winch. It was a while ago, I'd have to look it up again myself.
Nice job! Seems like a easy enough job that i even can do?????
This might be my answer for my 36" beastly snow thrower? Can't justify a hydraulic unit for my # 109 NIK,
It dont cut grass, but its yellow. |
hf winch
Lonnieb
I have a hf winch that I am using a dpdt momentary switch to control.A form member gave me the tip on wiring the switch and so far working good.
Ed Wells Jeffersontown Ky |
Thats a pretty neat idea! I have pondered the idea of putting a winch on a cc, if nothing else for retrieval of doa machinery and such.
Sam,2-149,102-with creeper,102,125-parts,147,682,682-Cub Ca-table,1440 4cyl-(work in progress),3165,154 lo-boy with 3 cyl. diesel, Shed full of parts and accessories |
