front weight bar with mule drive
Need some thoughts and opinions on combining the two to use on my "parts 100"
I already have the weight bar for the front and a mule drive that needs work and was thinking that i would just cut the old mule drive to fit the weight bar so i wouldn't have to remove and replace possibly damaging paint each time that is done. I am concerned that when plowing that with the mule drive hanging down it will get hung up on the ground a bit, subframe will be removed at the pin of course when plowing. It will hang an additional 3 inches lower but if you measure 6 inches from the ground up (trying to simulate it in the trench)it would clear but nearly hitting. Has anyone plowed with their mule drive on and had trouble?
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
I have plowed with my 100 with a Brinly 10" and the front mule drive on (I couldn't get one of the screws out ) and had no problems at all. I have since removed the screw and taken it off as I won't be mowing with it.
Good luck, David |
I'm planning to bolt my 100's weight bracket to the same bolts that hold the front grill on the frame.
Main reason is clearance issues like you had post.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Ha im at 50/50 and get the same here lol not really wanting to mow with it alot just if needed. Its going to get hydro lift eventually and hoping to do more plowing than mowing!!!
Something more like this? I can still use the mule drive and keep the weights on.
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Thats a nice 1450 Daniel.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: |
Thanks Donovan! I fully restored it and now Jed has it again. And still going strong!
hoe did you make the front weight bracket.
dieseldan123, got any close up pics of the weight bracket? i want to have a weight bracket/bumper mounted to the front of my 1650. this way i can use my mule drive and weights at the same time. i dont want to drill any new holes though.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
