Greg Rozar AKA- CubDieselFan
Old 10-20-2014, 01:35 PM
Jim M Jim M is offline
Default QA42 gearbox bearings
I am trying to find out if anyone has had luck with finding bearings that cross from the IH part numbers? I need to rebuild my gearbox and want to replace the inner and outer bearings along with the seals.
these are the numbers I have
475-627-r91
475-628-r91
485-306-r1
I seen that Ihccw had some, but only had 1 inner and didn't list any seals.
hope someone can help!!!
Thanks
Jim
Old 10-20-2014, 03:25 PM
gdheck's Avatar
gdheck gdheck is offline
Take the old bearings and seals out and there will be a manufacturer number on them. Careful with the seal, so you don't damage the number. All you have to do is take those to a bearing supplier. The last time I did one, IBT had them in overnight.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 10-20-2014, 03:31 PM
both seals were melted And I cant read the outer numbers. I found the inner ones were r12 bearings and I think the outer ones have a number 1630dctntg18. still nothing for the seals. But thanks for the tip. If you would have the seal number could you let me know?
Thanks.
Old 10-20-2014, 03:53 PM
gdheck's Avatar
Ok, I'm on my own computer now and have the numbers.
Inner bearing is R12
Outer bearing is 1630DC or I think a BR9930 works too.
Seal is a 471643
Your bearing supplier should be able to verify that the OD and ID of the bearings and seals are all the same.
Old 10-20-2014, 08:42 PM
When I rebuilt mine, I took the bearings right into the bearing supply store and they matched them up. I told them what they were for and had the gear box housing and shafts in my vehicle if they needed any more info ( they didn't )
Old 10-30-2014, 01:21 PM
Thank You for your help!!
Seal is a 471643
Old 10-30-2014, 05:10 PM
Seal is a 471643
When you list numbers, sometimes a bearing or seal number is specific to a manufacturer. You should list the manufacturer just for certainty. The seal number you gave is a National seal number. But the same seal in SKF is a 7628. The bearing numbers are correct, and not manufacturer specific.
Old 10-30-2014, 06:01 PM
gdheck's Avatar
I don't think I had a manufacturer to go with numbers.
If anyone goes to a bearing supplier with these numbers and they can't get you the right bearing and seal, leave as fast as you can! That supplier probably couldn't get the correct bearing and seal if they had the old ones right there in front if them.
Old 10-30-2014, 06:13 PM
I don't disagree there!!
But sometimes even my bearing and seal company needs to know who made it to help with a cross.
