Anyone built a poly pipe for lawn irrigation "pipe layer"
For their Cub Cadet.
And have pics to share? I am imagining a hunk of 2" steel pipe with an easy sweep 90 degree bend. Leading edged with steel plate to make like a cutting edge. Coil of poly pipe would be up above vertical end of 2" pipe. My yard is basically grey beach sand and I only have to lay it in 6 or 8" deep. |
May not be much help, but I've watched this video a few times and think it's a cool setup.
https://m.youtube.com/watch?v=KsFMsrnXAv8
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. |
I remember seeing what your talking about in the home made section of MTF.
http://www.mytractorforum.com/ Basically a sub soiler with a pipe sweep behind it. http://www.mytractorforum.com/78-law...type-tool.html http://www.agrisupply.com/point-pipe...ipper/p/73622/
I built a cable layer with a long sweep elbow of 2 inch metal conduit strapped to the back of a subsoiler. Pulled it with my Ford 2000. Buried lots of direct burial UF cable. Would easily handle putting in irrigation pipe. Might not have enough traction with a cub cadet unless your soil was very soft, so you might want to rent a 4wd sub compact or larger tractor with a cat 0 or 1 hitch.
I think it will pull it, no problem. If I can pull a moldboard plow 5-6" deep in Illinois clay, he can surely pull a single rip shank 8" in sand. |
thanks guys!
it will be a single time use so it ain't gonna be pretty! |
