Spindle Seal
Received my new seals 10-12535 (48" deck #289 ) replacement for 921-3018A. Seals have no circular spring backing up seal lip - they look frail compared to originals. Is this some kind of improvement???? Bob
The spring is not needed on the spindle seals. If it was used as an oil seal that had some pressure the spring helps keep the seal tight around the shaft. Install the seal backwards on the bottom side so that it will let the pressure out when you grease them.
