Old 04-06-2013, 11:38 PM
goldie68rockfarmer goldie68rockfarmer is offline
well just to let you all know i have rest of 1572 took a part. monday i will get rear end case back from soda blaster . then will take rest of tractor to soda blaster and hopefully it will come home painted in a week or two.i think it will only take a weekend to reasemble.hope to have rear end gear back in by end of week. and if anyone finds my glasses please let me know where they are. hard to work on this stuff just by feel.
Old 04-07-2013, 12:18 AM
Awesome news! From my experience it takes longer to put everything back together then you think. Don't forget to tape off your ground locations so you get good grounds. BTDT
Good luck with finding your glasses.
Old 04-07-2013, 12:24 AM
Thanks for the update!
Old 04-08-2013, 10:14 PM
ok got cast case back put hydro pump on. tempary put pto clutch assembly over hydro shaft . i understand i need to drill cast case for the two bolts{17@18 partstree 433 rear pto} to hold the bearing assembly .now for the pto clutch assembly it has a squair plate with holse in it. my question is what are the holes for is there something that bolts to that or they just extra holes cause this clutch field asembly also works on other michines you can look on parts tree parts number 21 on {433 rear pto} and see the holes.?
Old 04-08-2013, 10:31 PM
Goldie, not to high-jack this thread but you don't need to drill anything. Download the manual from here and it explains it all. You need the 383/433 manual.
http://ccmanuals.info/pdf/
Old 04-09-2013, 06:39 AM
dag1450 dag1450 is offline
From the one picture i saw it ether bolts inside to # 14 or no bolts in outside corners. What r u going to do about the rear diff cover plate that has 3 or four studs coming out ? It does look like that pto was put on a cast rear in a 982. Does the fuel tank look like it will fit ? Dave
Old 04-11-2013, 12:09 AM
well fuel tank will not work . the fuel outlets hit on top of left axle houseing .nothing can be done to make it fit.so that leaves me 2 ways to deal with this .one build a fuel tank to go where the battery is and get some finders with battery under the seat or build me a new fuel tank for under the seat. and for the rear cover with the studes i have the alu. rear plate that i can get the bold pattern from. most likely i will have new rear plate lazer cut. cause the old cast plate has the oil fill plug in the way it will ned to be relocated . i will have new seales here saterday. and al so have appointment saterday with michine shop to drill the bearing suppert for rear pto. good thing only a half mile drive to any place i need to go like cub dealer/lazer cuter/body shop/farm store/the metal fab shop
Old 04-11-2013, 07:01 AM
Are u in this to deep to turn back now $$$? What if u find a aluminum rear that will bolt right in ? In one of my 2072's i have a rear out of i think a 2084, same rear center as 1572 but with larger axle tubes and looks heavy duty. Dave
Old 04-11-2013, 09:46 AM
Now we know the answer. But it sounds like a work around is possible.
Old 04-12-2013, 07:22 AM
Goldie, do you have enough clearence to plug the two bottom holes and come in from the top of the tank?
