#41
Pull rear fenders, power wash EVERYTHING, re route some hydraulic lines, install starter relay, install a headlight relay, drain rear end, new hytran, new filter, grease zerks, new engine oil, new engine oil filter, new air filter, remove wheel weights & fill rear tires with washer fluid, scrape off old decal glue, try and buff plastic to a moderate shine, install new decal kit, power wash deck, grease zerks, sharpen blades, paint belly of deck, install deck, build new three point arms, sell old 3pt arms, wax everything up and... hope that's it!
#42
Nope, we need more pics.
#43
So I took apart the power steering valve and the end of the shaft, where the snap ring is, has a snap ring, washer, and another metal bushing called a retaining plate. There's a lot of play in that end. It's not the end with the plastic bushing, it's the end with the snap ring. Is there supposed to be this much play in it or do I need to replace the retaining plate? There's a lot of play, a good 1/8" gap when you push the shaft to one side.
#44
Actually at one end of the tube, there's just a plastic sleeve, no bearing, and at the end I have pictured is just a washer and this #29 retaining plate that is really sloppy. I can't figure out why it would need to be sloppy since that's the end that feeds and locks into the valve. Seems like any slop would put pressure on the seals at that end, which is where I think it was leaking. It really needs to at least have another plastic sleeve like at the other end, or a bearing would be better. Unless someone tells me it's supposed to be sloppy, I may spec it out and see if I can find a bearing to fit. That little metal #29 retaining plate is $19 and the plastic "bearing" at the other end is $29. Seems like i could find some bearings for that price, depending if they are a common size.
#46
IIRR,
The shaft lower end is supported farther down by what it slips into, not by the steering housing tube. |
#47
Ahh, so the retainer plate really doesn't ever touch anything because the end of the shaft slips through the next piece of the housing.
#48
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
#49
Can you post a picture of it?
#50
This is not a hacksaw and grinder job...
Is the part still available? Or is that a machine shop replica type deal? A26C6078-1079-45AB-8AB7-E1D68B606818.jpg Edit: looks like part number 1679026SM and it’s about $166 if it’s available.
