#31
This is a perfectly timed thread. I have a spare steering unit in my garage that leaked like that, and I plan to rebuild it in the spring.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
#32
Well, I received my kit this week and attacked the orbital on Saturday. Would have been done in about 45 min, but I got cocky on the last segment going back together and the Jesus Springs ended up setting me back about 40 minutes. So all in all, after torquing the unit together, bout 1.5 hours total.
Decided to try it today after installing the lines last night. To my amazement, large streams of oil did not appear, and the steering wheel actually moved the wheels correctly. I'll check it out better after the whole tractor is pressure washed. The thing operates really smooth and sounds better. It also doesn't make that strange noise when hitting the end stops.
#33
Good work, Sir!
For everyone who has rebuilt a steering valve. Do you put new springs in or just the orings?
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#34
Well done
#35
Ya did good junebug.
Always like a "happy ending" |
#36
Good job! What kit did you end up getting? FYI, it helps to have an ice cold beverage while rebuilding those.
#37
It's not as bad of a job as some think. Except for the springs you sailed right through it. Good work!
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#38
Ordered my seal kit....and a new set of springs....just in case!
#39
Thank you Sam! Thanks George! Happy ending...photo finish... It all feels good at the end Yup, except... I had 3 o rings left over. But my valve ports only used 4 seals, it doesn't have a relief, so that for sure eliminates another. So the only thing left is the one remaining small o-ring... Quote:
Thank you much! And thanks for guidance aswell! Hopefully the next one will go faster, but still not bad considering a new orbital is 600+
#40
Good job finding the springs and your completion of the repair.
What is next?
