Man O'man,... I'd love to have that 3pt. and cultivator on my 100.
![]() Nice looking project, thanks for the pictures. ![]() RoninKS |
I like to power wash any Cub that I'm going to paint.
![]() ![]() ![]() Tractor is disassemblied. Al the parts are check for wear and best way to remove paint. Sandblast pile: ![]() ![]() Nonsandblast pile:
Parts after sandblasting:
![]() ![]() ![]() ![]() Parts are primered with a sandable primer: ![]() ![]() ![]()
The grill was pushed back some. Someone drilled a second set of holes so the hood could clear the steering wheel.
![]() Here is how the hood looks primed. There is only 1 hole on each side now. ![]() White parts were painted first this time. ![]() ![]() ![]() ![]()
Looks great Dale! Thanks for sharing your pics.
Awesome job. Wish that I had the know how to do that to my 127..
Brake is not working right on the 70 and the tractor is hard to push. I desided to drain the oil in the rear end.
![]() This doesn't look good. ![]() There was an half inch of junk inside the rear end. ![]() Little rust on the gear shifter base ![]() Now to repair the brake. The brake linkage needs to be removed first. ![]() Remove the front cover. ![]() Remove big reduction gear. I used a impact to remove the center bolt. ![]() Remove the 4 bolts holding the reduction housing on. Housing pulls straight off. The brake disc will stay in the housing. ![]() Housing/disc off the rear end/trans. ![]() Clean up time. |
Thanks for the pictures. I really like the pop bottle idea.
The o-ring on this piston was the reason the brake was hanging up.
![]() I will clean the bore the piston fits in. ![]() The new o-ring is greased so it makes it easier to install the o0ring/piston assembly. Trans/rear end clean. ![]() ![]() ![]() New Gaskets for trans: ![]() Service manual is needed.....some of the bolts need torque. Trans going back together: ![]() I like to paint the front and rear covers.
Looks Great!! Thanks for the pics.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23 Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor |
