Old 03-23-2013, 11:36 PM
DLE140 DLE140 is offline
Default 102 Steering column rebuild
Hello,
Rebuilt the steering column in my Cub 102 today. Don't know if this was done before but I wanted the top of the column to look orignal but also to have a ball bearing instead of a bushing. So I used a dremel tool and ground out the center of the original bushing retainer. Switched to a sanding drum on the dremel and sanded down the lip of the new bearing just a little bit. Installed the new bearing in the column tube and tapped the modified bearing retainer down over the new bearing and on to the column. The retainer now holds the new bearing in place and once the steering wheel is installed it will look original.
Have a good day!
Old 03-24-2013, 12:01 AM
macman81's Avatar
macman81 macman81 is offline
its hard to upgrade and still look original sometimes but your idea does both.
thanks for sharing
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-24-2013, 01:03 AM
That turned out great! Good tips of those of us that want that factory look.
Old 03-24-2013, 08:06 AM
Yeah, nice job!
Old 03-24-2013, 09:09 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
thats a good idea, nice work!
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-24-2013, 09:10 AM
vartz04 vartz04 is offline
i am hoping the bearing makes a big difference. I might have to do this too when I put mine in I like it.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-24-2013, 10:08 AM
Great job! Thanks for sharing.
Old 03-24-2013, 12:09 PM
Nice job
Old 03-24-2013, 02:30 PM
cjrolke cjrolke is offline
where do you get the bearing from
everythgin i seem to find is the smaller wheel bearing style
thanks
Old 03-24-2013, 03:03 PM
Default Steering Column Rebuild
cjrolke, You can use a 3/4" Cub Cadet front wheel bearing. It fits a little loose in the steering column tube but the modified bearing retainer will hold it in place.
Thanks for all the comments everyone
