Old 09-04-2009, 08:57 AM
rfrank's Avatar
rfrank rfrank is offline
Default homemade lift rod
The lift rod I got with my 54in blade had been bro ken and welded by the PO. So I decided it didnt look too pretty and I didnt want to drill a 5/8 hole in my lift arm, so I made one. 25in piece of stainless pipe, fused nuts on the ends with a tig welder and screwed in some threaded rod gate supports from tsc for about 25.00 in materials all together. I worked it hard in the gravel driveway for about 3 hours and it didnt break or bend. I think it will hold up. The ends are adjustable in case you want a little more down or up. pics for your viewing pleasure.
Old 09-04-2009, 09:50 AM
zelda's Avatar
zelda zelda is offline
Nice, I like it . . . Given me some ideas. I'm refurbishing my snowthrower. Looks like a lot better lift rod than I have for it. Maybe even give a little more lift to it.
Old 09-04-2009, 04:10 PM
Nice work, rfrank! Thanks for sharing.
Old 09-04-2009, 09:25 PM
rfrank,
Nice looking lift rod
Old 09-04-2009, 10:10 PM
rfrank's Avatar
I like the fact that I can adjust it for more lift for pushing snow this winter, and lower it a bit if i need to dig with it. Took me about 15 minutes to make this once I figured out what I wanted to do. If anyone is interested I can make a few for just above cost and shipping, I drilled a 11/16 hole in my lift to allow for the 5/8 rod. So the smaller 1/2 inch hole can still be used for the snowblower if the need arises.
Old 09-15-2009, 12:39 PM
MFP8055 MFP8055 is offline
I just started a thread on the length of this lift rod. What's it supposed to be?
IH 1650, CC 1210, 1610 and Bolens 1257
Old 09-28-2009, 04:10 PM
klejeune's Avatar
klejeune klejeune is offline
I saw this idea a few years back and did this as well. I already had the 1" tubing so I just needed the gate hinge bolts. My welds don't look as pretty though.
So I could space it out away from the Frankenstein bolts I stacked up some washers and put a bead down the side to hold them together.
I like pie
Old 10-10-2009, 12:15 PM
D_Ordway D_Ordway is offline
Rfrank I an interested in one of the lift rods that you have made if you could give me an idea no the price and how much it would cost to ship it to zip 14859
