John,
No I did not want to comment that you got them free.
Free is free, it is what it is, 6 of one 1/2 dozen of the other.
The ones with the curved arms are for a wide frame, I just put one on my 1541, I did have to change the lift arm bracket and use the 82 series lift rod. I also had to grind a 1/2 off the backside of the ears to clear the axle adjusting bolts, but you will not have to do that.
But as it is you will need the 82 series bracket and 3/4" rod to put it on the 782.
It is not going to fit on the 124.
Up to 530 and counting...
