I figured I'd have a nice relaxing time mowing with the 125 right after lunch today. Check oil, almost to the top line. Top off with gas, start it up and back out of the shed. I pull the garage door down and when I turn around, the mighty Cub is smoking like a mosquito fogger
Shut it off and notice an oil line on the right tire plus the muffler is coated on the bottom with oil.
NUTZ, the front seal gave up. Take a quick look and I can see it's out of the block a bit.
Pop the grill off, unhook the mower belt, loosen the PTO rod to move the lever front and realize I didn't line up the cutouts for the PTO.
Luckily I push it in just enough with my hand on the lever to get the 1/2" I need to get it lined up.
Grab a 1/8" allen wrench, all six hex screws come out and the pto loosens up easily. That comes right off. Remove the lock screw off the bearing eccentric and get that loose. ( I put it on and knew which way to hit to get it loose
Turns out the bearing is rusted to the crank
I find my three jaw puller and ARGGGHHH, the screw is too long. ( hits the grill frame )
I chuck up a piece of 3/8-16 all thread in the lathe, put a point on and part ( cut ) it off. Since the puller was a 12mm thread, the 3/8 all thread fits in the hole and I use a washer with a nut to pull the bearing. Since the nut was on the inside of the three jaw puller, I had to use and open end 9/16" wrench. Turn a little bit , flip the wrench and turn a little bit more. Flip the wrench and repeat---MANY times
Finally the
bearing comes off. I call the local NAPA and they have to order the seal. Just as well as they closed at 3:00 and it was 2:52 when I called. It's almost 5 miles away in town.
What was my wife doing during all this? Mowing our almost one acre property with the push mower
When I reinstall that bearing, it's getting a coating of antiseize on the crank nose. The above "fun fest" took 2-1/2 hours and I spent a hour forty five minutes
with that bearing.
Oh, as far as insult, I make a really nice PTO pulley puller and my PTO pulley just slid right off
Laugh, smile and have a beer while saying "it sucked to you today"
