Originally Posted by Masmith
A friend of mine was using his 109 with a replacement 12 hp motor in it when it shut off and won't start. It cranks but won't fire up. Any input on the first place to start would be great. The motor has ran great for years with no issues. Electrical problems are not my strong point. I am more of a parts changer in that area than a trouble shooter. Thanks in advance.
Does it have fuel? Check that first, I know it sounds to easy, but sometimes it seems like there is plenty of fuel but there's not. Can you smell fuel when your cranking it over? If not pull the fuel line at the carb and see if you have gas coming out the hose, that will rule out hat problem.
Check to see if it has spark. Check those out first and we can go from there.
Does it try to start, or just turn over without a puck?
