View Single Post
  #21
Old 12-02-2017, 08:33 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Originally Posted by CUBRAT View Post
I will do this when my rubber mounts arrive. Thanks!
That won't tell you whether that was the issue when solid mounted...
I'd pull the driveline, and fire her up. If it still shakes that bad, then you have an issue with the motor. Solid mounted or not, the motor should not have that much vibration. Eliminating it with rubber mounts will simply mask it.
Also, you haven't said whether you put in a solid driver. If you did, it is my understanding that running one with ISO mounts is a bad idea.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
