View Single Post
Old 08-28-2017, 10:15 PM
Originally Posted by Workinprogress View Post
Everything drilled. Started welding parts up.
Completed one side of the lift arms. Took some time to build a jig to have the correct spacing and alignment. Then welded some washers onto the side plates. Progress ended when I ran out of welding wire.
What kind of welder are you using? Are you running flux core wire?
