+1 on the epoxy primer. It's well worth the extra cost for protection and the adhesion is like nothing else. If you're set on BC/CC for everything, it may be worth your time to look into a higher quality line of basecoat. Yellow tends to be a little more transparent than most and what may take 3-5 coats to hide with cheaper stuff (like PPG Omni MBC) would likely cover in 2-3 with better stuff (like PPG Deltron DBC). Since you can do the same job with less paint it can actually be cheaper to use the higher line base. Lately I have been using Deltron base with everything else from the Omni line because that's what several body shops in my area have been doing. On my 102 I'm using PPG MTK series urethane single stage for the yellow. It's kinda nice because the color and clear is all together so I save time and don't have as many chances to get dirt in my fresh paint! On my cast parts like the rear end, I sprayed epoxy primer and went right to topcoat. I'll be using 2K primer surfacer on my sheet metal when I make it to that point. I also plan on wet sanding the sheet metal and clearing over the single stage for a little extra shine. I don't have a lot of time to spend in the shop right now, so progress has been slow. I don't have any pics yet, but I will try to get some posted of what I have so far. Good luck!
Proud owner of too much stuff!!
71, 102, 122, 123, 104, 127, 282 Hydro
(And that's just the Cubbies!)
I swear honey, just 1 more!!
