View Single Post
Old 05-21-2018, 06:44 AM
I went through the same issue a couple years ago. Found a used flywheel, removed the ring gear and swapped it to my flywheel. Drilled out the rivets then drilled and tapped the flywheel and used some socket head button screws I had. Think they were 1/4-20 but not sure. Anyway they just fit nicely into the recess on the ring gear.
