Originally Posted by R Bedell
Sorry..........that was an assumption on my part
It was about half throttle. I'm curious why do you say it should be 30 Vac? I see some documentation that says it should be 20 Vac also...with the only differences in the size of magnets inside the flywheel? And since the stator and voltage regulator are the same for both, shouldn't the regulator still put out the correct DC voltage, but just at a lower amperage?
Regardless, I'll test the stator again tonight at full throttle instead of half. All the readings reference 3600 rpm, but I don't have a tachometer for it.
