The last item I check out is the 3 pin driver.
The picture shows the wear on the pins. Worn pin(s) will make the holes in the clutch disc go oversize and the pins could shear off. It will make the clutch go out of balance and the tractor will have the shakes.
I will replace the bushing in the 3 pin driver too.
