View Single Post
Old 01-12-2018, 08:28 PM
guido guido is offline
Default Front wheel bearing experiment
The front wheel bearings seem to fail every season when I mount the snow thrower. To combat this I am experimenting with installing two sets of bearing per wheel. (If two are good... Four are better... Right?) Four of the bearings flanges were turned off in the lathe allowing them to be pressed below the hub face.
These wheels will also be getting a set of Terra Trac tires.
We shall see how well this works if I get enough snow to need the thrower.
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
