Originally Posted by olds45512
Most starters will handle both 6 and 12v, you wont hurt it.
Kind of.... You can give a starter more volts than it's "rated" for. But it will get hot a lot faster. You can burn them up. Just can't crank on them as long when you double the voltage... but you can use double the volts on them. You can give a 12V starter 24V too. Again... just can't crank very long on it.
S/G: I suppose the starter side would work, but it won't generate ~12V if it's a ~6V.
The WH is the wrong color isn't it... should be red.
