Not many Cadet ZTR users here. If you have a bad vibration when you engage the deck, its probably a bent blade, loose blade, spindle bearing gone, belt coming apart, idler pulley (or its mount or spring tensioner) or if its shaft drive, a Ujoint. you should be able to check all of that in just a few minutes.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
